The Z Coupler!
Creality brand 3D Printers!
The Z Coupler!
Lot's of people reporting issues with theirs....looks like mine is started to turn into a Slinky too
Dim3nsioneer
Re: The Z Coupler!
Post by Dim3nsioneer »
Did you never have problems with shifts in z direction? I tried a flexible coupler on my UMO once and then immediately removed it again.
Re: The Z Coupler!
Dim3nsioneer wrote: August 1st, 2017, 3:57 am Did you never have problems with shifts in z direction? I tried a flexible coupler on my UMO once and then immediately removed it again.
No.
Though bought a used Hictop an they shipped it assembled sort of.
They removed the top Aluminum Frame an laid into a box loosely with the steppers still attached to the couplers and lead screws.
You probably figured out the couplers were stretched beyond belief, could not help but LOL when I saw your couplers, as it reminded me of this.
Re: The Z Coupler!
The remarkable thing is that the printer is doing some amazing prints, but I do need to replace this with something better.
Several others have had this happen and this seems to be the replacement they suggest.
http://a.co/dacDwfT
They also suggest making sure everything is aligned, checking that the z screw lines up with the stepper. Some use a spacer to adjust the motor over a bit. I am not sure if this happens in shipping, from being banged around....or poor quality control.
Re: The Z Coupler!
Make your choice - Choosing a Coupler
https://www.nbk1560.com/en-US/products/ ... epage_012/
MBB-C - Bellows-type Flexible Coupling " 1st Choice"
Most coupler's can be found here
https://www.nbk1560.com/en-US/products/ ... fgodMjII5Q
jonnybischof
Re: The Z Coupler!
Post by jonnybischof »
Omg, is someone seriously still doing that :D
It really doesn't take a rocket scientist to tell that using a flexible coupling there is a really bad idea. I'd also recommend an Oldham coupler similar to the one you found there on Amazon. Personally, I'd go with a quality brand product, but these things can be quite expensive (Misumi Oldham couplings cost 15+ EUR, and that's the "cheap" ones with grub screws instead of the clamping design).
Re: The Z Coupler!
TinyMachine is supposed to be carrying better replacements soon. I don't mind paying more for quality
5mm to 8mm
I checked out the links @Roberts_Clif gave and got 105 results. Yikes! Which one!
Re: The Z Coupler!
LePaul wrote: August 11th, 2017, 9:46 am TinyMachine is supposed to be carrying better replacements soon. I don't mind paying more for quality
5mm to 8mm
I did suggest the MBB-C - Bellows-type Flexible Coupling " 1st Choice"
I agree buying a better replacement part is the way to go.
